Nu gaat het terugstellen van de achterste remzuigers erg zwaar
5. The calliper piston is now obvious. Notice that it has ‘lugs’ on its surface to aid rotation: the piston needs to be screwed back into the calliper in order to insert the new brake pads. Use the special tool to aid with this, or use an old screw driver etc. to turn the piston clockwise. Keep an eye on the master cylinder reservoir to make sure that the hydraulic fluid being pushed back into the brake circuit is not over flowing!
Ik heb het al 100den keren gedaan en al vele klauwen helemaal ontmanteld en gereviseerd.
