bartje01 schreefColonDit is volgens mij de officiele manier om de afstandsbediening te synchroniseren.
1. Remove the battery, take care not to touch the circuit board.
2. Press and hold each button in turn for at least 5 seconds (discharge fob)
3. Fit a new battery (CR2032)
4. Reassemble the handset.
5. Unlock the car using then key and operate the handset lock button four times to re-sync the handset.
succes
