em-gee-efke schreefColonNiemand???
If you're looking to fit a set of wheels which are non-standard you will find out that there is very little choice of wheels that bolt straight on to the MGF and TF. To overcome this problem we have redesigned these popular adapters which now allow wheels with a PCD (pitch circle diameter) from 98mm to 114mm to be fitted to the MGF & TF. This caters for virtually any 4 stud wheel. Although the price has increased slightly to cover the cost of additional studs now supplied it will allow the re-use of the standard wheel nuts and locks which can cost £30-£40 a set. Price is £120.00 plus VAT (£141.00)
