Here's the new list
- new dashboard
- new dashboard clocks (speedo-rev thingie), but not required
- new instrument bezel
- steering rack
- relocate master brake cillinder
- new brake lines (between ABS unit and relocated master brake cilinder)
- underbonnet black plastik cover
- something with the wipers, but not required
- lenses of the headlights
- set of mirrors (to be confirmed)
- door lock(s) (not required)
- door handle (not required)
- carpets (kind of required)
- sunvisors (not really required, depends on where the wife's sitting)
- main harness (to do with cable lengths)
- heater assembly
- fuse box bracket (now I see... it's about relocating the under-the-dashboard fuses, I had my mind set on the under-bonnet fuses. Ouch, this makes it a real mess and much more tricky to do).
Coen schreefColonHmm dat is wel jammer zeg. Kan hij de auto niet ombouwen? Koop een MG RV8 en bouw 'm om naar LHD, kun je er misschien wat op winnen
