Bruno schreefColonAnderzijds, Je hebt dus de Rave, dan zal je heel blij geweest zijn met je mail![]()
Hi Sanders,
I wondered already about what solution you found with the problem (saw the pix)
Anyway, the MGF has no mass meter. It's just *controlled* with the ECU, Throttle potentiometer and Stepper Motor (IACV)
There is as well a inlet temperature meter at the inlet manifold and a inlet air pressure sensor inside the ECU.
Mate, I assume you only have contact problems at any connector !! The same had I.
I suggest to once pull off all ECU related connectors an put them back. Check as well the strength of unwanted forces of wires at these connectors. The wires must run into the connectors with smooth curves without any force applied.
Hope this will help.
Regards
Dieter
