An Australian Project
  • andrew
    BerichtenCOLON 37
    GeregistreerdCOLON do jan 15, 2009 12:58 am
    WoonplaatsCOLON Melbourne, Australia
    door andrew » wo feb 25, 2009 8:34 am
    Well the FPR arrived but with out the requested gauge for adjustment. Never mind the workshop has one, so they start work on Tuesday............... its getting closer.........
    MG F Captain - MGCC Victoria
    MG F Register Regional Representative - Eastern Australia
    door Bruce » wo feb 25, 2009 10:19 am
    How would you typically calibrate that? I know Bruno did his during a rolling road test end just kept adjusting until he got the best performance result. Will you do the same? Or is there an alternative?
  • andrew
    BerichtenCOLON 37
    door andrew » do feb 26, 2009 2:58 am
    My guy say's using an exhaust gas analizer, will be 98% correct!. He does have plenty of experiance not just of F's, but old and BMW Minis plus his own very hot WRX.
  • andrew
    BerichtenCOLON 37
    door andrew » do apr 02, 2009 1:53 pm
    Well the workshop got busy and as my car was not on the urgent list, it was left until the last moment :( and nothing had been done. The only trouble was that I decided to do a motorkhana on the saturday so I retrived my car but with one difference. I had complained of a rattle from my exhaust, it was descoverd that my catalist had disintergrated so a pipe was welded through it making it a de-catted F, this coupled with a Miltek SS exhaust. I now have the loudest F in Australia :roll: which is causing a problem or two as it's even more than the 95 decibel limit for race tracks. As our National Meet is only just over a week away, I have left all modifications till the first week of May except if I can find one , a new/secondhand cat'.
    door Mr. Dj M. » do apr 02, 2009 2:59 pm
    Quite irritating when people don't do what they said they would do, hopefully you will get help :wink:
  • andrew
    BerichtenCOLON 37
    door andrew » di mei 05, 2009 11:24 am
    Well have started to strip down the engine but before I fit the new head and cam does any one have pictures of the correct position of the offset dowels.
    door ErikB » di mei 05, 2009 12:48 pm
    I am sure Bruno and/or Sander will pop in to help you with the dowels. I haven't got them myself (set of veniers on the shelf), but they have them on their cars.
  • andrew
    BerichtenCOLON 37
    door andrew » wo mei 13, 2009 10:16 am
    Well have just got the F back, had another minor set back, after fitting the FPR it would not pull, after pulling their hair out the workshop found the fuel pump had given up. I have a half roll cage, this componded the problem as it had to come out to get to the fuel pump. To get the cage out the seats have to come out. The O.E pump is expensive over here but we found a Bosch high presure one that was built for a Holden Commadore Turbo at the cost of only $100. I have only driven 15km so far,noticed more torque and a car that pulls all the way to the rev limiter. The real proof will be at the weekend when I go to a hill climb http://vimeo.com/1460777 .
    Has it been worth it, I will let you know next week.
    Laatst bijgewerkt door 2 op andrew, in totaal 0 keer bewerkt.
    door Mr. Dj M. » wo mei 13, 2009 10:19 am
    Sounds good already, hopefully it stays that way for you :wink:
    door ErikB » wo mei 13, 2009 11:34 am
    A bit of a strange thing that the fuel pump gives up, just after some work has been done on a FPR. Are you sure they didn't screw up.
    If the fuel pump is suspected, you may never forget to have a look at the connector on top of the pump. Some of them desintegrate in a rather spectacular way.
  • andrew
    BerichtenCOLON 37
    door andrew » do mei 14, 2009 6:23 am
    My car a 98 MG F VVC has done 161000km so I was not surprised that it packed up when asked to do more, and at least I should not have a problem in that area for a while ( fingers crossed). Today I hav e just returned from a quick blast of 100km on all types of road to see what she can do, the exhaust is much deeper in sound and the power from 5000 to 7250, well it just PULLS and PULLS using an exhaust gas analiser the FPR is showing4.1bar on the dial. Tomorrow I am getting just a pwer dyno test done to get an idea whats at the rear wheels and then I hope the weather stays nice for the hillclimb at the weekend.
  • andrew
    BerichtenCOLON 37
    door andrew » vr mei 15, 2009 2:26 pm
    Power dyno result 90kw at 7100rpm, it feels stronger than that!
    door ErikB » vr mei 15, 2009 2:31 pm
    That will be 122bhp, at the wheels I suppose.
    Resulting in a 141bhp at the flywheel.
    Is there a chance you could post the graph, as top power doesn't say much ?
    door Carl » vr mei 15, 2009 2:51 pm
    141 BHP at the flywheel, about as much as the VVC, but possibly much better spreading around the RPM range.
    The non-vvc has much better torque, so the figure sounds interesting.
    Eager to see the graph too!
    Have a great time at the Hillclimb this weekend! (some pictures are always welcomed :-) )
  • andrew
    BerichtenCOLON 37
    door andrew » do mei 21, 2009 2:23 am
    Could not work out how to post dyno graph so sent it to Bruce.
