door Bruno » vr jul 30, 2004 1:01 pm
En ik citeer verder nog even de Rave :
Speedometer (Up to 2000MY)
The speedometer is driven by a worm gear system
from a flexidrive input. The pointer is controlled by
an eddy current movement.
A seven digit odometer and a four digit trip distance
readout up to 999.9 miles or km is fitted.
Speedometer (From 2000MY)
The speedometer is operated electronically by a
signal output from a speed transducer fitted to the
gearbox. The transducer output is shared with the
EPAS ECU.
Odometer and trip distance is displayed on an LCD
located at the bottom of the speedometer. A button
allows the trip and odometer to be displayed
individually. The button will also reset the trip meter
if pressed and held. The LCD also shows gearbox
information when the vehicle is fitted with a
Steptronic (EM-CVT) gearbox.
Tachometer
The tachometer signal is taken from the MEMS ECU
to the control board which is secured to the rear of
the tachometer sub-assembly. The instrument panel
display reading is averaged over all the engine
cylinders to reduce fluctuations due to individual
cylinder retardation in spark timing which may occur
on engines fitted with programmed ignition systems.
