MGF schreefColonAls MG-Rover liefhebber wordt je toch verre van vrolijk van dit soort foto's.
ErikB schreefColonMaar 't is wel een schat wat die mannen daar op de gevoelige plaat vastleggen.
Op 28days vind je makkelijk een 500-tal foto's van Longbridge.
RinceWind @ XPowerForums schreefColonThat MG TF with the wider track and so on was the next generation TF. It's a pity the photo wasn't more side on as you'd see the increased length of the wheel base (100mm or so). This was the form the basis for the new TF and new TF coupe and the current floorpan was to become the new Midget.
The cut out's on the bonnet were to direct the hot air out from the repositioned radiators at the front of the car to imporve cooling. It was to have a new steering system and brakes system along with a whole raft of changes and it was aiming for the top of the tree with regards everything. It was also package protected for the KV6 engine. It was also going to use a 6 speed PG1 box called Hurricane. 17 and 18" wheel options and a rather fantastic interior with the introduction of "organ pedals" or floor mounted/hinged throttle and possible the brake/clutch too.
I was working in Targets & Strategy when this was being conceived and I was on the test that help set the targets for the vehicle. It was going to be fantastic and the development car you have seen in the flightshed was the chassis car.
Nic
