Herbie needs technical help, near Eupen / Aachen
  • Dieter
    BerichtenCOLON 21
    GeregistreerdCOLON vr nov 11, 2005 1:30 am
    WoonplaatsCOLON Bad Hersfeld, Germany
    door Dieter » vr sep 09, 2011 12:43 pm
    Hi Forum,
    just had a call from Herbie.
    He's currently only co-driver in Bruno's car @ the 1000 bochten run.
    Herbies MGF ist standing near their Hotel in Eupen? or Olpen? (didn't get the name right, though)
    The backbox has got very hot. Herbie assumes a brocken catalyst and blocked exhaust.
    Give him a call or short message to his mobile,
    +49 160 xxxxxx [edit number removed]
    in case you could suggest a quick solutiion to bring him back on the road before monday.
    I.e. with a spare catalyst or bypass pipe or workshop suggestion and things like that.
    It's an MK1 MGF, means straight catalyst without bend.
    I've put the same call to the German forum http://www.mgboard.de/viewtopic.php?p=46393
    Thanks for your assistance.
    Laatst bijgewerkt door 1 op Dieter, in totaal 0 keer bewerkt.
    Dieter
  • Dieter
    BerichtenCOLON 21
    Re: Herbie needs technical help, near Eupen / Aachen
    door Dieter » vr sep 09, 2011 2:32 pm
    current status:
    Option to supply a second hand backbox with catalyst.
    Under investigation by User Mykel from the german forum. Parts located in Aachen.
    Dieter
  • Dieter
    BerichtenCOLON 21
    door Dieter » vr sep 09, 2011 3:22 pm
    notice from another User....
    ---- cut -----
    Had a similar Problem with hot backbox and smoked carpet in the boot.
    Reason was a broken ignition coil.
    --- cut end ---
    Farward to Herbie by short message
    btw. Standard MGF MK1 no VVC
    Dieter
    door RemcovanKuilenburg » vr sep 09, 2011 9:54 pm
    Saidly to hear this. Hope he will enjoy with Bruno and can fix his car. But Bruno is there so it would be fixed in no time.
  • Dieter
    BerichtenCOLON 21
    door Dieter » zo sep 11, 2011 4:53 pm
    update:
    Ignition coil sourced *in any way* -stop-
    MGF technical task force on the way to the car :mrgreen: -stop-
    Press thumbs .... :shock:
    Dieter
  • Dieter
    BerichtenCOLON 21
    door Dieter » zo sep 11, 2011 6:44 pm
    Got a call.
    Thanks for pressing thumbs (in the name of Herbie) :mrgreen:
    Problem solved. Car runs fine and smooth...
    .... after proper refitting the ignition centre cabel of the distributor cap ;)
    Had come loose whyever and caused ignition confusion, resulting in overheated catalyst and exhaust, and smoked boot carpet.
    The master of BECK'S Bier is on the way home now :thumbsup:
    Dieter
    door RemcovanKuilenburg » zo sep 11, 2011 7:46 pm
    Glad to read that it is all right now.
    door ErikB » ma sep 12, 2011 7:32 am
    Good news.
    @Herbie: did you use the new ignition coil or have you left that one in Belgium (Bruno) ? If you still have it, no problem I will order a new one.
    Great fun during the weekend dough.
    door Bruno » ma sep 12, 2011 10:42 am
    I have it, no problem !
    We could not check the problem, because of the fact the car was located 140 km's from our hotel. To do a diagnostic then was really hard :wink: . A shame we thought not on Friday about this option, because I understood from Herbie that the car was going well, but above some higher refs, there was a lack of power. It seems anyway, that I must understood Herbie wrong, otherwise he had had his car on the "1000 Bochten". A shame !
    Thanks Dieter and the others for the help !
    door ErikB » ma sep 12, 2011 10:45 am
    Damn ... no chance to earn some money ;)
    jokes aside, really happy it is solved that easy and cheap.
  • Herbie
    BerichtenCOLON 536
    WoonplaatsCOLON Bremen (D)
    door Herbie » di sep 13, 2011 3:45 am
    Ohhh, nu moet ik in Engels posten :lol: ;)
    Thanks everyone for the help, support and taking care of me ! Sunday evening I went to Mykel and stayed there until Monday morning for a more relaxed drive home. MG - truly the marque of friendship ! :thumbsup:
    Dieter, special thanks for crossposting in the forums, I owe you a beer (or ten :lol: )
    All parts I want to replace are now ordered (incl. brandnew heatshield, stainless bolts and nuts etc.). I had lot fun going back home, all the way up to Bremen via countryroads. Sometimes I floored it really hard, I think I was infected by Bruno's style :mrgreen: :thumbsup:
  • Herbie
    BerichtenCOLON 536
    door Herbie » za sep 17, 2011 4:41 pm
    Just to finish this episode
    Underside
    New Heatshield
    New sportscat, unbelievable sound now :thumbsup:
    (pic a bit blurry but I just had no more power in my arms, pre-cleaning again :? )
    Carpet, blanking plugs etc. are on order and then ready for new adventures ... or not due to lack of money :lol: :lol:
    door RemcovanKuilenburg » za sep 17, 2011 8:12 pm
    Herbie,
    Dat ziet er weer goed uit. Je kan wel zien dat het aardig warm is geweest en je geluk hebt gehad.
  • Herbie
    BerichtenCOLON 536
    door Herbie » za sep 17, 2011 8:24 pm
    Yep Remco, dat was werkelijk schaars ! 8)
    Edit: kunt u deze thread naar Allgemeen bewegen met een nota in de titel "opgelost" ?
    door ErikB » zo sep 18, 2011 2:03 am
    Hoe was de staat van de catalysator ?
