An Australian Project
  • andrew
    BerichtenCOLON 37
    GeregistreerdCOLON do jan 15, 2009 12:58 am
    WoonplaatsCOLON Melbourne, Australia
    door andrew » do jan 15, 2009 8:49 am
    My high KM F VVC is a 97/8 model which I have owned for 6 years. In our club competition I have been the third placed F for most of the past five years.
    It was time to give the old girl a lift. I have two sets of Trophy 16" alloys, one set for road one track and AP 4 pot calipers. A Trophy 160 cylinder head is being cleaned and ported, Piper BP270H and Dave Andrews offset dowels. The exhaust manifold will be left as standard due to local rules but with a Miltek SS exhaust. All this being feed via a 52mm TB and Taipan Cold air induction. I have run poly bushes, lowering knuckles and adjustable shocks for the past five years. The car has a half roll cage and 4 point harness.
    So maybe I can keep up with TF160's.
    Tyres are a problem, no not road but track, there are no 195/45 plenty 205/55x16", no 215/40 x 16" but 205/55 or 225/45x16". The 55 profile is to high and a 225/45 is towide for a 7" rim. As my first competition event for this year on 8th Feb is close, Iwill run Toyo R1R 205/45x16 www.toyo.com.au/Proxes%20R1R%20Press%20Release.htm
    Laatst bijgewerkt door 1 op andrew, in totaal 0 keer bewerkt.
    door Bruce » do jan 15, 2009 8:57 am
    G'day Andrew,
    Welcome to the MGF.be forum, been a while since we spoke last, hope you are well?
    I have taken the liberty of moving your post to the international section of the forum so we keep it in a language you can read. :lol:
  • andrew
    BerichtenCOLON 37
    door andrew » do jan 15, 2009 9:12 am
    Thanks Bruce, still wearing your T shirts and have to explain the' be' bit.
    I tried to post my usal avatar but it seems to be to big, I will try and find something smaller. Congratulations on the new part of your site, a very good idea.
    MG F Captain - MGCC Victoria
    MG F Register Regional Representative - Eastern Australia
    door ErikB » do jan 15, 2009 10:35 am
    Hello Andrew, welcome.
    Strange rules overthere regarding the manifold. Changing the exhaust and the head, but keeping the manifold. Is there a possibility to tweak the original manifold. I am sure, they (those who serve the law) won't notice....
    door Bruno » do jan 15, 2009 10:38 am
    hi Andrew, glad to see that you have registered the forum, you wear clothes of.
    Nice to see, the other site of the planet is also represented. You are the second one from Australia here. Bruce was the first one ! :wink:
  • andrew
    BerichtenCOLON 37
    door andrew » do jan 15, 2009 2:16 pm
    If I use a 4 -2 -1 manifold the car becomes a special so I move up a class. I also have a Quaife LSD but to be honest I don't think it offers a lot. If you go to Rob Bells site you can see pictures of my car in his Chamber of Horrors section.
  • andrew
    BerichtenCOLON 37
    door andrew » di feb 03, 2009 8:06 am
    Well I have the Toyo R1R's they look fantastic, but seem very soft. Have only driven about 30km, just to the workshop to get the other bits done, and they felt fine. Our temp has been in the 40C + range but I hope by the weekend the temp will come down so the track won't be that hot. It looks like I will be bedding every thing in on the way, never enough time. Will let you know how the car feels and go's next week.
    door Bruce » di feb 03, 2009 9:23 am
    Oo nice, I've not seen the r1r before...
    Nice and hot is good for the tyre... haha you should atleast get a 100 km out of them.. a friend lives in Adelade and it was 45.7 last week.. I can't even emagine how hot that would be, my max is 41 and that was killing...
    lucas
    BerichtenCOLON 2331
    door lucas » di feb 03, 2009 9:36 am
    Bruce schreefColonOo nice, I've not seen the r1r before...
    try Egypt in july ... marvellous dry climate and sunny weather :wink:
  • andrew
    BerichtenCOLON 37
    door andrew » vr feb 06, 2009 10:24 am
    Temp tomorrowis ment to be 47C the hottest February day on record and Sunday should be 37C at the track.
    Disapointment, went to collect my car only to find the new head and cam have not been fitted. The cam was to tight in the carrier and had been sent away to be linned bored and had not been done in time, infact finished today but not leaving enough time to be completed as I will be leaving very early to beat the heat tomorrow. My mechanic is worried that the standard mems computer might not be up to the job as the head has been gasflowed and might run to lean, we won't know this until we can run it on the road using the gas analizer.
    The four pot brakes using EBC rotors and red stuff pads are just brilliant, so with good tyres and brakes I will try and set a PB without power but on handling.
    door Kasper » vr feb 06, 2009 10:28 am
    andrew schreefColonTemp tomorrowis ment to be 47C the hottest February day on record and Sunday should be 37C at the track.
    Had to scrape of the ice from the windscreen at 8:00 in the morning before leaving :wink:
    Lots of success with your project :thumbsup:
    Keep up the good faith
    door Mr. Dj M. » vr feb 06, 2009 10:58 am
    I didn't even knew Mgs where sold in Australia! :roll:
    door Bruno » za feb 07, 2009 11:50 am
    andrew schreefColon. My mechanic is worried that the standard mems computer might not be up to the job as the head has been gasflowed and might run to lean, we won't know this until we can run it on the road using the gas analizer.
    A FPR is you friend. :wink: Mine is on 4,5 bar by the way, and running fine (checked on Dyno) :wink:
  • andrew
    BerichtenCOLON 37
    door andrew » zo feb 15, 2009 1:22 am
    Ordered a FSE power boost valve which should arrive about Friday next, so then will get the whole lot done at once. It's getting closer, patience Andrew!.
    door Bruno » zo feb 15, 2009 1:06 pm
    :thumbsup:
